Thanks a lot House_Cat,
I have two more questions, please
1- What is the most efficient way of using autorouter,
a) to group Nets in schematics and then after pre-routing sensitive/difficult nets use Auto-Route All
b) After placement and pre-routing use Auto-Route Component/Net lock good routes and again Auto-Route Net/Component...
if 'a' is most efficient when is most useful to use Auto-Route Component/Net/Area/Room
I feel this is not a good question because situation may vary from board to board but if you give me a basic theme that can be applied to many(if not most) boards of what is the most efficient way of using Situs Auto-Router (beginning from schematics) I really appreciate it.
2- In some months ago I remember I asked you a question about guard rings and you showed me a link that had some experimental graphs that showed guard rings are not much better than just increasing clearance. Since then I encountered many datasheets from different manufacturers Analog Devices/ Burr-Brown,.. that strictly recommended using guard rings for some sensitive ICs. e.g. very high impedance Opamp electrometers,..., why they are so commonly recommended? are they useful if you can't increase clearance enough but instead you can inset a very narrow, low clearance guard between aggressive track and victim track?
Thanks again,
