LM35DZ model for proteus
Fragrance
East Of Earth
lm35dz proteus
hi
here is the virtual model of proteus for lm35dz
regards
Fragrance
lm35dz
hi
both non working models removes to avoide confusions
regards
Fragrance
Re: lm35dz
can u send me the mplab code for this project?
thanks and nice work
hi sir fragnance,
thanks for this, for the virtual model regarding LM35 with pic micro controllers.i have the same project as this but as an experiment, i am trying to ouput the data to LED's, and with different pic, i will be using pic18f4620 cause im planning to use the zigbee regarding LM35 as heat sensor. very big thanks to this. till then
This thread is dated about 4 years ago when LM35 wasn't available in proteus and this model had to be used but in the new versions (v7.6, v7.7 etc) the LM35 model is already included in proteus and working fine.
Alex
Alex
sorry i thought it's new because it's in new posts...
Ihave protues 7.8.. it should have LM35
hi sir fragnance,
by the way, is it possible to output the data from the LM35 to pic18f4620 down to corresponding LED's? i mean like the reading from LM35 is 25 degrees Celsius pass down to pic18f4620 which is analog signal right? with ADC.. the corresponding output will be 0001 1001... 8 LEDs will display the reading from LM35, LED on= 1, LED off=0. i know its complicated rather than using LCD to see the output, but its just an experiment,was wondering. thanks in advance. sorry if i have mistakes on my own understand how LM35 and microcontroller communicates. im open on any corrections :)
---------- Post added at 17:08 ---------- Previous post was at 17:06 ----------
sir alexan_e
ive tried this a while ago,on proteuse, it was working though thats why im curious on another experiment. thanks for the information sir.
hello! i downloaded the file and have copied the library and the model files in my proteus folder, im having this error(see attached screenshot) when i attempt to simulate it...im using proteus 6 btw, its kinda obsolete i know, but i don't have the proteus 7 as of the moment, so i need to use the resources i have right now =) hoping for your response =) thanks in advance! ^_^
thanks for the reply, like i said, my proteus is version 6...it doesn't have lm35DZ that's why i have to download this file. =)
