Hello all,
I have a communication system based on a 915MHz carrier wave.
The communication is for less than 1 meter.
No need for PA in the system.
What are the options for the antenna in the circuit
10 simple wire soldered to the PCB transceiver (wire - 50 ohm)
2) Chip antenna
3) PCB antenna (wires routed in the PCB)
I want to use the first option - simple wire.
Can you tell me what would be the difference in the quality of the transmitted signal if I use wire instead of a chip antenna or PCB antenna?
Thanks
82 mm assumes a straight wire.
If I were you ,I would use a simple and cheap 915 MHz di-electric SMD antenna.They don't occupy too much space..
https://www.digikey.com/product-det...logy-inc/0915AT43A0026E/712-1535-1-ND/2392134
Cheaper than simple copper rod..:wink:
It's not that simple. The trick with these small "antennas" is that they require a very well defined large ground, and depend on that ground. Changes to the ground size will detune the antenna.
The occupied area is just roughly 10mmx20mm, so it's not critical thought.
What do you mean by "occupied area"? I refer to the required ground plane size for such devices (much larger than device size), not to the device size. From my epxerience in designing miniaturized 915MHz antennas, you always co-design these antennas for a given ground plane size. 10mm x 20mm total sounds a bit small to me.
Application of this antenna has been well illustrated here..
https://www.mouser.com.tr/datasheet/2/611/0915AT43A0026-242364.pdf
All monopole antenna designs involving a small ground plane can be better analysed as asymmetrical dipoles. The actual impedance depends on the geometry of both parts. That's obviously also true for the suggested ceramic antenna, the manufacturer requires a specific ground plane shape to achieve 50 ohm impedance. A different shape gives a different impedance and thus requires a matching network for optimal performance.the device is small, but its performance depends on that large PCB ground for a total size of 20mm x 49.5mm. You cannot use that small device to build a small PCB.
