dksoba
Member level 2
Hi All,
I need a roughly 90vdc power source for a brake on an AC motor. At this stage, I'd just like to simply release the brake. The resistance of the brake at room temperature is 1.2kohm. At 90v, this corresponds to a current draw of 75mOhms, correct? I'm not sure the best way to make a 90V power supply, so what I'm wondering is if I can make a simple full-bridge rectifier to rectify AC to DC, and have some filter capacitors and of course a fuse. I've not made such a power supply before and I've messed around w/AC *very* little. However, it seems like right now it's a good choice and I need to learn about AC electronics more and more.
Right now, my plan is to use a 2kv variac (which I have on hand) to slowly raise the voltage in a full-bridge rectifier -> capacitor -> load circuit. This way I can test if my rectifier is working as I hoped at *really* low voltages, and slowly raise it up to the voltage I need. However, AC scares the crap out of me so as a sanity check I thought I'd run it by ya'll.
Please advise,
Thanks,
Matt.
Please advise,
Thanks,
Matt.
