Help with Oscillator in ADS
skyismylimit
Member level 1
Member level 1
how to check whether my oscillator has sufficient gain for start up in ADS?
I am working with a colpitts oscillator. I couldnt run the transient simulation as it says lots of warnings when i use the ATC components from ADS.
I used HB analysis, but the manual says it is a steady state simulation. It asks me to test with osctest component. Also, it mentions that the characteristic impedance value of the osctest component may affect the results. I am not sure of wat value to use for the Z value in the osctest component.
Is there any other way to test the start up? Or any rectification for the two methods i have tried?
Please help..
what is the transistor u use , and what is the frequency ? of operation
Khouly
Check the closed loop gain and phase to maintain the oscillation conditions. If they are sufficiently satisfied, the circuit may oscillate.
The best check out method to apply a small transient simulation by forcing a simple pulse over loop path.
I am using a new device which is a SOI MESFET. I have a non linear model for the device. the frequency is 400MHz.
I tried transient simulation but it is giving unreasonable values of KV at the output. There are warnings about the ATC components Imapfreq when i run the transient simulation.
Is the HB analysis only for the steady state?
hi friend
I also faced same problem with ADS
The good solution while working in ADS is
Test your individual components that is apply transiant simulation to each component(say microstrip line) & observe response.
If it is expected directly go for fabrication of oscillator.
best of luck
sure HB analysis is steady state analysis . but it is very efficient in oscillator analysis and phase noise calculation
khouly
