S parameter simulation in cadence
chinito
Full Member level 2
Full Member level 2
s parameter simulation
Is there a tutorial out there that explains simple S-paramter simulation on cadence i.e. what kind of voltage source with port number and termination should be used, what analysis to run, how to plot S11,S12,S21,S22 etc? many thanks in advance.
sp analysis cadence
port type voltage source , then Do SP analysis chosing the ports in the analysis setting and the freq. range
check cadence manual for more details
