ywguo
Junior Member level 2
![Junior Member level 2](/styles/images/ranks/clevel2.gif)
Hi, Guys,
How to remove assign statements in synthesized netlist? Some Astro versions do not allow assign statements in verilog netlist.
In Advanced ASIC Chip Synthesis, it states that the following command should be set in a script.
verilog_no_tri = true
set_fix_multiple_port_nets -feedthroughs
set_fix_multiple_port_nets -all -buffer_constants
I follow the above rule. It failed.
Any help is welcomed.
Thanks
Yawei
Thanks
Yawei
