Printed circuit handbook by Clyde f.coombs.
squecuec
Newbie level 2
Newbie level 2
disadvantages programable unijunction transistor
hi,
can anyone provide the link for good analog question , cmos questions ?
thanks
analog questions
i m in need for problems for interview. problems regarding transistors, opamp, cmos ,
etc of electronics.
Re: analog questions
If you are preparing for an interview just stick to the basics. Know the following
(1) Capacitor charging and discharging
(2) Basic Amplifier circuits -- How feedback is achieved in CE ?
(3) Oscillation criteria
(4) Op Amps
(5) Rectifier and regulator
BRM
analog questions
Hi
I think that Adel sedra is a good book for this issue.
thanks
Malvino is a very good and precise book for the purpose of interview and broad overview purpose.
Here is a list for Opamp related interview question.
1. Bode-plot, Phase-margin and Frequency Compensation in Two-stage Op-Amp
2. Gain-splitting using miller-capacitor in Frequency compensation
3. Where is the dominal pole? estimate the magnitude of dominal pole and other poles
4. If the first stage is telescope or folded-cascode, estimate its max swing, headroom
5. When used as unity-gain buffer, estimate its slewing rate
Hi
I wil suggest u to see millman halkias its bible , another good book is boylsted
analog questions
Hi
ART OF ELECTRONICS - This book is very good and you can find lots and lots of good stuff on analog and cmos
I also like the book "Art of electronics"
About the interview make sure you know:
1) Parasitic element
2) Zero-pole behaviour of amps
3) Compensation
4) Steps involved in designing an amplifeir
5) May be a number of questions on Hspice or ADS or even PSpice
analog questions
what is Parasitic element ?
analog questions
Hi
Parastic Element of an antenna, is a directive element that is not connected to a radio transmitter or receiver either directly or via a feeder, but is coupled to the driven element only by the fields.
you should know the stability of an amplifier ,and mos characteristics and the relevant equation..and also some basic digital circuit fundamentals...like setup time..,hold time,current mirrors etc..
analog questions
razavi‘s book
you can solve many basic question after read it
quick and easy understanding analog principles use analog IC design by John and martin
Hi
What are the basics that someone should know for Analog design?
analog questions
when mentioning about analog design, nowadays, the voltage supply, power is very essential. You may wanna study more about the folded cascode amplifier as well.
A firm knowledge of MOS and BJT would be basic as well.
Biasing circuitry is aslo very important.
analog questions
go for analog you can go for
millima hawkis,or boyester
cmos by weist
mainly concentrate on basics..........
analog questions
razavi‘s book
it is hard to read ~
