Tutorials/manuals for CST Microwave Studio
junction_crosstalk
Junior Member level 2
Can anyone give me tutorial/manual file of Microwave Studio of CST?
cst tutorials
If you have CST, the pdf documents (Getting started, Tutorial, Advance guide) are all in your CST installation directory under the documentation folder. If you still can't find them, pm me.
Cheers,
Element7k
tutorial cst
I have a SWF that is tutorial of dipole antenna with CST Microwave Studio v4.3.I upoded here:
cst 2008 tutorial
part 4-6
    V
    kbr
    saeed6244
cst tutorial videos
CST Tutorial
  • getting_started_1253.pdf
cst +tutorial
mtts,what cst version here?,i ask if u can plot many frquencies polar pattern on same polar chart?
also ask if u have two curves in cst,could u can subtract them?
regards
cst+microwave+studio+2008+example
Anybody know how to design a microwave absorber?
I want the tutorial about how to design the pyramidal absorber.
What the common material that use? what the dimension, size and high of the absorber?
Added after 11 minutes:
Hello.
Where is we can find at the internet about the tutorial, demo and other notes about how to learn about CST Microwave Studio?
I want to design a pyramidal microwave absorber but do not know what is the best material that can we choose, the dimension, size and other specification.
Anybody can helped me to solved the problem?
cst tutorial
Can CST simulate the design from ADS??? and if yes? how it can be works?? any ideas??
Thanks
Added after 1 minutes:
which one is better or more accurate?? CST or ADS or HFSS?? need advice
cst tutorials agilent
Thanks
Please see the attached file:
CMOS VCSEL Driver Design using CST MICROWAVE
STUDIO® and Agilent ADS
cst microwave manual
CST and ADS can simulate together by installing a design kit. HFSS easy to learn, ADS for 2D simulation, CST not very easy to learn but once you master it you will feel it powerful :)
cst tutorial pdf
Hi Dear;
please i would ask you if you have some other example training for CST simulation. the example that you have posted on this forum is very good to practice CST. thakn you very much.
if you have others video, can you please send it to me on my e-mail: najwa_news@hotmail.com.
i'll be grateful. thakns a lot.
best regards
cst+tutorial
Anyone know how to design helical antenna using cst or any notes that i can refer
regards,
kyg
subtract cst microwave
Hi KYG, ver. 2006 has a script for generating a helical wire under the MACROS tab. You can also generate one yourself with a simple script.
1) Generate a 3D polygon of points in a helical path using a for loop --> something like "for zz=0 to zEnd step zStep", "xx = R*cos(Ang)", "yy = R*sin(Ang)", and "Ang = Ang + dAng" where dAng is the angular increment given by "dAng = WirePitch*zStep*2*pi". The WirePitch is the number of twists per unit length.
p.s. If you don't want to use a script, then generate these points in excel and import them using "Curves-->3D Polygon-->Load File"
2) Generate a circle, the cross-section of the antenna.
3) Sweep the circle through your helical path using "Curves-->Sweep Curve". Also, use PEC as the material.
Hope this helps.
Nate
cst getting started guide
Hi guys, Can I get a tutorial on a circular waveguide for CST?
thanks
