C source code for Radix-2 FFT decimation-in-frequency algori
atmelAVR91
Member level 4
Member level 4
Need C source code for Radix-2 FFT decimation-in-frequency algorithm
Re: C source code for Radix-2 FFT decimation-in-frequency al
Maybe this code will be useful for you
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <sys/time.h>
#define PI 3.14159265359
#define MAXPOW 24
struct complex
    double r;
    double i;
int pow_2[MAXPOW];
int pow_4[MAXPOW];
void twiddle(struct complex *W, int N, double stuff)
    W->r=cos(stuff*2.0*PI/(double)N);
    W->i=-sin(stuff*2.0*PI/(double)N);
void bit_reverse_reorder(struct complex *W, int N)
    int bits, i, j, k;
    double tempr, tempi;
    for (i=0; i<MAXPOW; i++)
	if (pow_2[i]==N) bits=i;
    for (i=0; i<N; i++)
	j=0;
	for (k=0; k<bits; k++)
	    if (i&pow_2[k]) j+=pow_2[bits-k-1];
	if (j>i)  /** Only make "up" swaps */
	    tempr=W[i].r;
	    tempi=W[i].i;
	    W[i].r=W[j].r;
	    W[i].i=W[j].i;
	    W[j].r=tempr;
	    W[j].i=tempi;
void bit_r4_reorder(struct complex *W, int N)
    int bits, i, j, k;
    for (i=0; i<N; i++)
	j=0;
	for (k=0; k<bits; k+=2)
	    if (i&pow_2[k]) j+=pow_2[bits-k-2];
	    if (i&pow_2[k+1]) j+=pow_2[bits-k-1];
	    tempr=W[i].r;
	    tempi=W[i].i;
	    W[i].r=W[j].r;
	    W[i].i=W[j].i;
	    W[j].r=tempr;
	    W[j].i=tempi;
/** RADIX-4 FFT ALGORITHM */
void radix4(struct complex *x, int N)
    int    n2, k1, N1, N2;
    struct complex W, bfly[4];
    N1=4;
    N2=N/4;
    /** Do 4 Point DFT */
    for (n2=0; n2<N2; n2++)
	/** Don't hurt the butterfly */
	bfly[0].r = (x[n2].r + x[N2 + n2].r + x[2*N2+n2].r + x[3*N2+n2].r);
	bfly[0].i = (x[n2].i + x[N2 + n2].i + x[2*N2+n2].i + x[3*N2+n2].i);
	bfly[1].r = (x[n2].r + x[N2 + n2].i - x[2*N2+n2].r - x[3*N2+n2].i);
	bfly[1].i = (x[n2].i - x[N2 + n2].r - x[2*N2+n2].i + x[3*N2+n2].r);
	bfly[2].r = (x[n2].r - x[N2 + n2].r + x[2*N2+n2].r - x[3*N2+n2].r);
	bfly[2].i = (x[n2].i - x[N2 + n2].i + x[2*N2+n2].i - x[3*N2+n2].i);
	bfly[3].r = (x[n2].r - x[N2 + n2].i - x[2*N2+n2].r + x[3*N2+n2].i);
	bfly[3].i = (x[n2].i + x[N2 + n2].r - x[2*N2+n2].i - x[3*N2+n2].r);
	/** In-place results */
	for (k1=0; k1<N1; k1++)
	    twiddle(&W, N, (double)k1*(double)n2);
	    x[n2 + N2*k1].r = bfly[k1].r*W.r - bfly[k1].i*W.i;
	    x[n2 + N2*k1].i = bfly[k1].i*W.r + bfly[k1].r*W.i;
    /** Don't recurse if we're down to one butterfly */
    if (N2!=1)
	    radix4(&x[N2*k1], N2);
/** RADIX-2 FFT ALGORITHM */
void radix2(struct complex *data, int N)
    int    n2, k1, N1, N2;
    struct complex W, bfly[2];
    N1=2;
    N2=N/2;
    /** Do 2 Point DFT */
	twiddle(&W, N, (double)n2);
	bfly[0].r = (data[n2].r + data[N2 + n2].r);
	bfly[0].i = (data[n2].i + data[N2 + n2].i);
	bfly[1].r = (data[n2].r - data[N2 + n2].r) * W.r -
	    ((data[n2].i - data[N2 + n2].i) * W.i);
	bfly[1].i = (data[n2].i - data[N2 + n2].i) * W.r +
	    ((data[n2].r - data[N2 + n2].r) * W.i);
	    data[n2 + N2*k1].r = bfly[k1].r;
	    data[n2 + N2*k1].i = bfly[k1].i;
    if (N2!=1)
	    radix2(&data[N2*k1], N2);
void main(int argc, char *argv[])
    FILE   *infile;
    int    N, radix, numsamp;
    int    i;
    struct complex *data;
    double freq, phase, fs, A;
    int    dotime;
    struct timeval start, end;
    long   totaltime;
#ifdef GEN
    if (argc!=9)
	printf("usage:\n");
	printf("    fft [A] [f] [phase] [fs] [num samp] [sequence length] [radix] [time]\n");
	printf("        output: DFT\n");
	exit(1);
    sscanf(argv[1], "%lf", &A);
    sscanf(argv[2], "%lf", &freq);
    sscanf(argv[3], "%lf", &phase);
    sscanf(argv[4], "%lf", &fs);
    sscanf(argv[5], "%d", &numsamp);
    sscanf(argv[6], "%d", &N);
    sscanf(argv[7], "%d", &radix);
    sscanf(argv[8], "%d", &dotime);
#endif
#ifndef GEN
    if (argc<4)
	printf("usage:\n");
	printf("    fft [input file] [sequence length] [radix]\n");
	exit(1);
    else if ((infile=fopen(argv[1], "r"))==NULL)
	printf("Error reading input sequence file: %s\n", argv[1]);
	exit(1);
    sscanf(argv[2], "%d", &N);
    sscanf(argv[3], "%d", &radix);
    dotime=0;
#endif
    /** Set up power of two arrays */
    pow_2[0]=1;
    for (i=1; i<MAXPOW; i++)
	pow_2[i]=pow_2[i-1]*2;
    pow_4[0]=1;
	pow_4[i]=pow_4[i-1]*4;
    if ((data=malloc(sizeof(struct complex)*(size_t)N))==NULL)
	fprintf(stderr, "Out of memory!\n");
	exit(1);
    /** Generate cosine **/
#ifdef GEN
    for (i=0; i<N; i++)
	data[i].r=0.0;
	data[i].i=0.0;
    for (i=0; i<numsamp; i++)
	data[i].r=A*cos(2.0*PI*freq*i/fs - phase*PI/180);
#endif
#ifndef GEN
    for (i=0; i<N; i++)
	fscanf(infile, "%lf", &data[i].r);
	data[i].i=0.0;
#endif
    gettimeofday(&start, (struct timezone *) 0);
    if (radix==2) radix2(data, N);
    if (radix==4) radix4(data, N);
    gettimeofday(&end, (struct timezone *) 0);
    totaltime=(end.tv_sec*1000000 + end.tv_usec)-(start.tv_sec*1000000
						  + start.tv_usec);
    if (radix==2) bit_reverse_reorder(data, N);
    if (radix==4) bit_r4_reorder(data, N);
    if (!dotime)
	for (i=0; i<N; i++)
	    printf("%f\n", sqrt(data[i].r*data[i].r +
				data[i].i*data[i].i));
    else
	printf("%ld us\n\n", totaltime);
#ifndef GEN
    fclose(infile);
#endif
thanks Jools,
I have few queries
1) your FFT algo C code is DIT (decimation in time) or DIF (decimation in freq)
2) how much FFT size is supported
3) will this work efficiently with uC like ARM7 TDMI ?
4) what is GEN constant ?
atmelAVR91 said:
thanks Jools,
I have few queries
1) It's DIF with radix-2 and radix-4 (selectable from command line)
2) Any size of power 2 (2^x) for radix-2 and power 4 (4^x) for radix-4.
3) I have not knowledge about this uC.
4) Input data from console if GEN is defined or from file if GEN is not defined.
    atmelAVR91
thanks jools
Please tell me what is MAXPOW and why it is set to 24
I have a quiery that how 512 point fft can be implemented by c language i want the details algorthim with source code please any body help me
rangababu
above C code presented will work for 512 points FFT
i want radix-2 decimation in time not frequency becoz it is more complicated i want also how u follow the algorthim pleease reply me
jools
I am getting incorrect output from your program see the attached Excel document
my input is clean sinewave of singal frequency, so output FFT should be singal Frequency bin.
but I am getting something different.
atmelAVR91 said:
jools
Hi !
It's correct. For а nice precision use a one of window functions for output FFT.
what kind of window function ?
can you recommand some.
Try Hamming window or Blackman window.
after applying Hamming window or Blackman window
FFT output will get corrected ?
because I am comparing output of your program with MATLAB for verification !
atmelAVR91 said:
jools
I have found origin of this FFT program.
Try this links
and
http://www.gweep.net/~rocko/FFT/
    atmelAVR91
Re: http://www.gweep.net/~rocko/FFT/
Hi Jool
I saw your code..
What is the input frequency?
And how to run that code in turbo in c
