Problem with UART in VHDL (Spartan 3E)
lythanhthuan
Member level 3
Member level 3
M.T.A-VN
I am working to FPGA(spartan 3) and i decided to form a simple vhdl code that sends to computer arbitrary data then i will try to add receiving part then extra something but whatever i do i couldnt manage it. plzz help me
My code is following :(i used no parity and baud rate 9600. my board clock is 50 MHz )
  library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library UNISIM;
use UNISIM.VComponents.all;
entity main is
generic(baud : std_logic_vector(12 downto 0):="1010001011000"; -- clock divider for baud rate
clk_increment : std_logic_vector(12 downto 0):="0000000000001";
shift_increment : std_logic_vector(5 downto 0):="000001"
Port ( sseg : out std_logic_vector(3 downto 0);
display : out std_logic_vector(6 downto 0);
tx : out std_logic;
rx : in std_logic;
clk : in std_logic;
switch : in std_logic);
end main;
architecture Behavioral of main is
component OBUF_LVCMOS33 port
( O : out std_logic;
I : in std_logic);
end component;
component IBUF_LVCMOS33 port
I : in std_logic);
end component;
component ibufg port
I : in std_logic);
end component;
component bufg port
(i : in std_logic;
o : out std_logic);
end component;
signal s_sseg : std_logic_vector(3 downto 0);
signal s_switch : std_logic;
signal s_disp : std_logic_vector(6 downto 0);
signal s_rx,s_tx: std_logic;
signal clk0:std_logic;
signal baud_fixer : std_logic_vector(12 downto 0):="0000000000000";
signal data_counter : std_logic_vector(5 downto 0):="000000";
signal baud_generator : std_logic:='1';
signal bit_clock : std_logic;
signal data_format: std_logic_vector(9 downto 0);
signal data :std_logic_vector(7 downto 0):="01100001";
signal data_to_send :std_logic:='1';
begin
segcom : FOR i IN 0 to 3 generate
seg0 : OBUF_LVCMOS33 port map
(O => sseg(i),
I => s_sseg(i));
end generate segcom;
switchcom : IBUF_LVCMOS33 port map
(O => s_switch,
I => switch);
dispcom : FOR i IN 0 to 6 generate
disp0 : OBUF_LVCMOS33 port map
(O => display(i),
I => s_disp(i));
end generate dispcom;
rxcom: IBUF_LVCMOS33 port map
(O => s_rx,
I => rx);
txcom: OBUF_LVCMOS33 port map
(O => tx,
I => s_tx);
clkcom: ibufg port map
( O => clk0,
I => clk);
bitgen: bufg port map
(i => baud_generator,
o => bit_clock);
s_sseg<="1001";
s_tx<=data_to_send;
-- baud rate generator
process(clk0)
begin
if clk0='1' then
if baud_fixer<=baud then
baud_fixer<= baud_fixer+clk_increment;
else
baud_fixer<="0000000000000";
baud_generator<= not baud_generator;
end if;
end if;
end process;
-- data shifter
data_format(0)<='0';
data_format(9)<='1';
data_format(8 downto 1)<= data(7 downto 0);
process(bit_clock)
begin
if s_switch='0' then
s_disp<="0100100";
if bit_clock='1' and bit_clock'Event then
if data_counter<"001001" then
data_to_send<=data_format(conv_integer(data_counter));
data_counter<=data_counter+shift_increment;
elsif data_counter>="001001" and data_counter<"011100" then
data_to_send<=data_format(9);
else
data<=data+"00000001";
data_counter<="000001";
data_to_send<=data_format(0);
end if;
end if;
else
data_to_send<='1';
data_counter <="000000";
s_disp<="0111111";
end if;
Re: UART with VHDL
BuBEE said:
TRY UART From xilinx it's good.
Anyone has the same code in Verilog? I have seen examples in Verilog for UART but they are super complex. I am looking for something simple so that it can be used as the most basic foundation for teaching Verilog?
Re: UART with VHDL
I have downloaded a verilog one before, but i forgot its site, any how here it is, hope it helps
    mbz99
    V
    chandan_c9
Re: UART with VHDL
Thanks yasser_shoukry
This was pretty much what I neede. The main .v file looks pretty simple - just what I was looking for
~B
