Hi, Im working on an 8088 based sine wave generator (variable freq.)
Uptill now I have connected one 8255 PPI (IO/M of 8088 connected to it's CS through an inverter),a 74LS373 (for demultiplexing the address bus)...an 8284 with 10 Mhz crystal. and a 27512 ROM 16 address lines and 8 datalines...
All this is currently connected on a breadboard.
I am getting the clock at 3.333 MHz (as expected) and ALE pulses at 833.3 khz (as expected), but I can't get the O/P on 8255's ports...
AD0 and AD1 of 8088 is connected (through address latch '373) to 8255... I am giving it the 80h as the control word and setting up some o/p values for the ports but nothing seems to work.
I tried include a WAIT statement to check if the processor tested the TEST pin..but it isn't, so i suspect it is not reading from the ROM at all.
I've placed a FAR JUMP (EA 0000 2000) at FFF0 of my ROM to the address where the program resides.
Also, is it required to BUFFER the data bus of 8088?...
I'll donate +10(+3) points to the one who can actually help me out....Thanks a lot.
