engineer khan
Member level 3
please anybody send me lcd all commands c programming 8051 microcontroller i use,,,,please also tell me that commands for 16x2 lcd and 16x4 lcd are the same or different
;* PROGRAM NAME : Lcd.ASM
;* DESCRIPRTION : Program for testing LCD display. 4-bit communication
;* is used. Program does not check BUSY flag but uses program delay
;* between 2 commands. PORT1 is used for connection
;* to the microcontroller.
;BASIC DIRECTIVES
$MOD53
$TITLE(LCD.ASM)
$PAGEWIDTH(132)
$DEBUG
$OBJECT
$NOPAGING
;Stack
DSEG AT 0E0h
Stack_Start: DS 020h
Start_address EQU 0000h
;Reset vectors
CSEG AT 0
ORG Start_address
JMP Inic
ORG Start_address+100h
MOV IE,#00 ; All interrupts are disabled
MOV SP,#Stack_Start
Inic: CALL LCD_inic ; Initialize LCD
;* MAIN PROGRAM
START: MOV A,#80h ; Next character will appear on the first
CALL LCD_status ; location in the first line of LCD display.
MOV A,#'M' ; Display character ‘M’.
CALL LCD_putc ; Call subroutine for character transmission.
MOV A,#'i' ; Display character ‘i’.
CALL LCD_putc
MOV A,#'k' ; Display character ‘k’.
CALL LCD_putc
MOV A,#'r' ; Display character ‘r’.
CALL LCD_putc
MOV A,#'o' ; Display character ‘o’.
CALL LCD_putc
MOV A,#'e' ; Display character ‘e’.
CALL LCD_putc
MOV A,#'l' ; Display character ‘l’.
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
MOV A,#'t' ; Display character ‘t’.
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
MOV A,#'n' ; Display character ‘n’.
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
MOV A,#'a' ; Display character ‘a’.
CALL LCD_putc
MOV A,#0c0h ; Next character will appear on the first
CALL LCD_status ; location in the second line of LCD display.
MOV A,#'R' ; Display character ‘R’.
CALL LCD_putc
MOV A,#'z' ; Display character ‘z’.
CALL LCD_putc
MOV A,#'v' ; Display character ‘v’.
CALL LCD_putc
CALL LCD_putc
MOV A,#'j' ; Display character ‘j’.
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
MOV A,#' ' ; Display character ‘ ’.
CALL LCD_putc
MOV A,#'s' ; Display character ‘s’.
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
CALL LCD_putc
MOV A,#'m' ; Display character ‘m’.
CALL LCD_putc
CALL LCD_putc
MOV R0,#20d ; Wait time (20x10ms)
CALL Delay_10ms ;
MOV DPTR,#LCD_DB ; Clear display
MOV A,#6d ;
CALL LCD_inic_status ;
MOV R0,#10d ; Wait time(10x10ms)
CALL Delay_10ms
JMP START
;* Subroutine for wait time (T= r0 x 10ms)
Delay_10ms: MOV R5,00h ; 1+(1+(1+2*r7+2)*r6+2)*r5 approximately
MOV R6,#100d ; (if r7>10)
MOV R7,#100d ; 2*r5*r6*r7
DJNZ R7,$ ; $ indicates current instruction.
DJNZ R6,$-4
DJNZ R5,$-6
RET
;* SUBROUTINE: LCD_inic
;* DESCRIPTION: Subroutine for LCD initialization.
;* (is used with 4-bit interface, under condition that pins DB4-7 on LCD
;* are connected to pins PX.4-7 on microcontroller’s ports, i.e. four higher
;* bits on the port are used).
;* NOTE: It is necessary to define port pins for controlling LCD operation:
;* LCD_enable, LCD_read_write, LCD_reg_select,similar to port for connection to LCD.
;* It is also necessary to define addresses for the first character in each
;* line.
LCD_enable BIT P1.3 ; Bit for activating pin E on LCD.
LCD_read_write BIT P1.1 ; Bit for activating pin RW on LCD.
LCD_reg_select BIT P1.2 ; Bit for activating pin RS on LCD.
LCD_port SET P1 ; Port for connection to LCD.
Busy BIT P1.7 ; Port pin on which Busy flag appears.
LCD_Start_I_red EQU 00h ; Address of the first message character
; in the first line of LCD display.
LCD_Start_II_red EQU 40h ; Address of the first message character
; in the second line of LCD display.
LCD_DB: DB 00111100b ; 0 -8b, 2/1 lines, 5x10/5x7 format
DB 00101100b ; 1 -4b, 2/1 lines, 5x10/5x7 format
DB 00011000b ; 2 -Display/cursor shift, right/left
DB 00001100b ; 3 -Display ON, cursor OFF, cursor blink off
DB 00000110b ; 4 -Increment mode, display shift off
DB 00000010b ; 5 -Display/cursor home
DB 00000001b ; 6 -Clear display
DB 00001000b ; 7 -Display OFF, cursor OFF, cursor blink off
LCD_inic: ;*****************************************
MOV DPTR,#LCD_DB
MOV A,#00d ; Triple initialization in 8-bit
CALL LCD_inic_status_8 ; mode is performed at the beginning
MOV A,#00d ; (in case of slow increment of
CALL LCD_inic_status_8 ; power supply when the power supply is on
MOV A,#00d
lcall LCD_inic_status_8
MOV A,#1d ; Change from 8-bit into
CALL LCD_inic_status_8 ; 4-bit mode
MOV A,#1d
MOV A,#3d ; As from this point the program executes in
;4-bit mode
MOV A,#6d
MOV A,#4d
RET
LCD_inic_status_8:
PUSH B
MOVC A,@A+DPTR
CLR LCD_reg_select ; RS=0 - Write command
CLR LCD_read_write ; R/W=0 - Write data on LCD
MOV B,LCD_port ; Lower 4 bits from LCD port are memorized
ORL B,#11110000b
ORL A,#00001111b
ANL A,B
MOV LCD_port,A ; Data is moved from A to LCD port
SETB LCD_enable ; high-to-low transition signal
; is generated on the LCD's EN pin
CLR LCD_enable
MOV B,#255d ; Time delay in case of improper reset
DJNZ B,$ ; during initialization
DJNZ B,$
DJNZ B,$
POP B
RET
LCD_inic_status:
MOVC A,@A+DPTR
CALL LCD_status
RET
;* SUBROUTINE: LCD_status
;* DESCRIPTION: Subroutine for defining LCD status.
LCD_status: PUSH B
MOV B,#255d
DJNZ B,$
DJNZ B,$
DJNZ B,$
CLR LCD_reg_select ; RS=O: Command is sent to LCD
CALL LCD_port_out
SWAP A ; Nibles are swapped in accumulator
DJNZ B,$
DJNZ B,$
DJNZ B,$
CLR LCD_reg_select ; RS=0: Command is sent to LCD
CALL LCD_port_out
POP B
RET
;* SUBROUTINE: LCD_putc
;* DESCRIPTION: Sending character to be displayed on LCD.
LCD_putc: PUSH B
MOV B,#255d
DJNZ B,$
SETB LCD_reg_select ; RS=1: Character is sent to LCD
CALL LCD_port_out
DJNZ B,$
CALL LCD_port_out
POP B
RET
;* SUBROUTINE: LCD_port_out
;* DESCRIPTION: Sending commands or characters on LCD display
LCD_port_out: PUSH ACC
PUSH B
MOV B,LCD_port ; Lower 4 bits of LCD port are memorized
ORL B,#11110000b
ORL A,#00001111b
ANL A,B
MOV LCD_port,A ; Data is copied from A to LCD port
CLR LCD_enable
POP B
POP ACC
RET
END ; End of program
