8051 digital clock by 7-segment !! help
Eng_Master
digital clock using 8051
hi all,
i need to make a digital clock by using 8051 microcontroller in assembler
and the display is seven segment not LCD
no decoders used
there are 3 switches :
1- one for modes ( hours,minutes and seconds)
2- the second for alarm
3- and the other for stop watch if possible
Any ideas?
thanks.
8051 digital clock
Sounds doable, what's the problem?
8051 clock
hey.........
are you talking about real time clock for the controller whhich shows the current date, & time.........
source code for a digital clock with 8051
There are two methods to make a clock:
1. Use timers for counting the seconds and increase some variables wich will be your minutes, hours, etc. This is not so accurate
2. Accurate method use some RTC (real time clock) chip, e.g. from Maxim Dallas. They've them on i2c or SPI
Regz
digital clock 8051
thanks to all
jigisha
Ok , No problem
by using real time clock. can u help me in source code?
but remember the display is 7-segment not LCD
Regards
digital clock using microcontroller
For an accurate clock
you have to calculate the delay of exact one second
depending on the frequencu of your microcontroller
and also depending on the internal clock divisor.
you have to also take into account the machine cycle an instruction will require
Regarding 7 segment interfacing it is easy using microcontroller
programe 8051 for clock with 7segment
sau_sol
i know that 7-segment interfacing is easy
but i need the source code in assembly language:!:
please help:|
thanks.
seven segment digital clock
I have the ASM,but the explanation is in chinese language.
qidao1920
any thing, i will try to understand
and the schematic of ASM if found
i'm waiting for your answer
regards
seven segment interface with 8051
blueroomelectronics
This project is sponsored me after a week from now in the university
i need any thing about it .....
digital clock, 7 segment display assembly
hi all,
can somebody help my
8051 clock code
For interfacing seven segment displays, I have some tutorials and source codes in assembly here
and for multiplexing seven segments
Hope this may help..
digital clock 7 segment schematic
Hi
its so easy.
see the circuit i am uploading.
you may use a 8051 and RTC chip.
Added after 1 minutes:
Clock Complete in Orcad
digital clock using 8051 microcontroller
Hi,many web sites has ready-made,or a Proteus project.HAHA
Reactions: irsa
    V
    irsa
