8051 assembly instructions list available
dxpwny
I made a sortable list of C51 assembly langaue instructions, with embedded links to an Atmel datasheet that I've used to better understand C51 operations.
its "ins_guide.html" at 8051bits.com. https://www.8051bits.com/ins_guide.html
The "clks" column actually shows the machine cycles for the instruction for the SiLabs C8051F340.
You can sort by any column by clicking on the column header. I meant to add the ability to only list certain instruction types by selecting the boxes at the top. That is not at all working yet. - it does NOTHING.
If you want to download that and use it locally, you can get the following files, and save the all in the same folder on you PC, then access it from there.
AtmelDoc0509.pdf
ins_guide.html
cpuSortTable.js
cpuSortTable.css
I'm not fluent in html/javascript - it took me hours to create this.
...... Arg ... my latest PC setup changes the way PDFs open, so the links to the specific pdf pages did not work until I disabled the Acrobat extension within Chrome.
