Here is the code
DONT FORGET TO PRES THE HEPLED ME BUTTON
module alu(CLK,RESET,A,B,Y,OP,C,N,V,Z);
// 8 bit arithmetic logic unit
// parameter:
// CLK.......system clock
// RESET.....System Reset
// A.........A input
// B.........B input
// OP........operation to perform
// Y.........8 bit result output
// C.........carry status
// V.........overflow status
// N.........sign status
// Z.........zero status
input CLK,RESET;
input [7:0] A;
input [7:0] B;
input [15:0] OP;
output [7:0] Y;
output C;
output V;
output N;
output Z;
// internal nodes
reg [7:0] Y,LogicUnit,AluNoShift;
wire [7:0] ArithUnit;
reg shiftout;
wire C,V,N,Z;
wire carryout;
wire ovf;
reg Neg; //negative status from ALU
reg Zero; //Zero Status from ALU
// Arithmetic unit
// gona use myAddSub for this part...it seems to work right...
// rather than trying to infer the thing.
// operation of the adder subtractor is as follows
// OP[0] OP[1] carry | operation
// 0 0 0 | Y = A - 1;
// 0 0 1 | Y = A;
// 0 1 0 | Y = A - B - 1;
// 0 1 1 | Y = A - B;
// 1 0 0 | Y = A;
// 1 0 1 | Y = A + 1;
// 1 1 0 | Y = A + B;
// 1 1 1 | Y = A + B + 1;
// Logic Unit
// OP[1] OP[0] | operation
// 0 0 | Y = A and B
// 0 1 | Y = A or B
// 1 0 | Y = A xor B
// 1 1 | Y = Not A
always @ (A or B or OP[1:0])
begin
case (OP[1:0])
2'b00:LogicUnit = A & B;
2'b01:LogicUnit = A | B;
2'b10:LogicUnit = A ^ B;
2'b11:LogicUnit = !A;
default:LogicUnit = 8'bx;
endcase
end
// Select between logic and arithmatic
// OP[2] | operation
// 0 | Arithmetic operation
// 1 | Logical Operation
always @ (OP[2] or LogicUnit or ArithUnit)
begin
if(OP[2])
AluNoShift = LogicUnit;
else
AluNoShift = ArithUnit[7:0];
end
// Shift operations
// OP[3] OP[4] OP[5] | operation
// 0 0 0 | NOP
// 1 0 0 | Shift Left (ASL)
// 0 1 0 | Arithmentic Shift Right (ASR..new)
// 1 1 0 | Logical Shift Right (LSR)
// 0 0 1 | Rotate Left (ROL)
// 1 0 1 | Rotate Right (ROR)
// 0 1 1 | NOP
// 1 1 1 | NOP
always @ (OP[5:3] or AluNoShift or C)
begin
case(OP[5:3])
3'b000: begin
Y = AluNoShift; //do not shift output
shiftout = 0;
end
3'b001: begin
Y = {AluNoShift[6:0],1'b0}; //ASL
shiftout = AluNoShift[7];
end
3'b010: begin
Y = {AluNoShift[7],AluNoShift[7:1]}; //ASR
shiftout = AluNoShift[0];
end
3'b011: begin
Y = {1'b0,AluNoShift[7:1]}; //LSR
end
3'b100: begin
Y = {AluNoShift[6:0],C};
end
3'b101: begin
Y = {C,AluNoShift[7:1]}; //LSR
end
3'b110: begin
shiftout = 0;
end
3'b111: begin
shiftout = 0;
end
default: begin
Y = 8'bx;
shiftout = 0;
end
endcase
end
// Generate the status bits for the status registers
always @(Y)
begin
if(!Y[0] & !Y[1] & !Y[2] & !Y[3] & !Y[4] & !Y[5] & !Y[6] & !Y[7])
Zero = 1;
else
Zero = 0;
end
