75ohm terminal resistor on video.
fyjin
Member level 1
Member level 1
75ohm terminal
Why CVBS signal select 75ohm terminal resistor?
Because it is common to use 75 ohm impedance cable for video. Audio is routed on 600 ohm parallel conductor lines. RF is usually used on 50 ohm lines.
