74LVT245, can I use it this way...
aleksaZR
Newbie level 6
Newbie level 6
Hi all,
At first, I wanted to use '245 to convert 5V signals to 3V3, uni-directional, direction A to B.
Input signals may be floating, so I've added 10k pull ups to 5V on side A of '245.
Now I need it to be bi-directional, but I don't know if the 5V pull ups will harm the 3V3 outputs on side A?
In this datasheet, where can I find that information?
It should be safe and you probably don't need the pull-up resistors. The critical factor is that the pins can withstand 5V while the device is tri-state but you have it permanently enabled anyway. Note that it will not convert from 3.3V and 5V though. A 5V on the 'A' side will be converted to 3.3V on the 'B' side but going the other way, 'B' will come out on the 'A' side at 3.3V. That may not be a problem as it would still meet normal TTL level specifications for a logic high and low.
Brian.
