hemnath
Advanced Member level 3
I am planning to get data from 16 channel multiplex(74HC4067) input into arduino uno.
I have connected I0 to I15 as +5V, on the serial monitor some of the pin values are showing as 0. Why is it 0 instead of 1?
// control pins output table in array form
// see truth table on page 2 of TI 74HC4067 data sheet
// connect 74HC4067 S0~S3 to Arduino D7~D4 respectively
// connect 74HC4067 pin 1 to Arduino A0
byte controlPins[] = {B00000000,
B10000000,
B01000000,
B11000000,
B00100000,
B10100000,
B01100000,
B11100000,
B00010000,
B10010000,
B01010000,
B11010000,
B00110000,
B10110000,
B01110000,
B11110000 };
B00010000,
B00100000,
B00110000,
B01000000,
B01010000,
B01100000,
B01110000,
B10000000,
B10010000,
B10100000,
B10110000,
B11000000,
B11010000,
B11100000,
B11110000 };
// holds incoming values from 74HC4067
byte muxValues[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,};
int inPin = 8; // pushbutton connected to digital pin 0
void setup()
Serial.begin(9600);
DDRD = B11111111; // set PORTD (digital 7~0) to outputs
pinMode(inPin, INPUT); // sets the digital pin as input
void setPin(int outputPin)
// function to select pin on 74HC4067
PORTD = controlPins[outputPin];
void displayData()
// dumps captured data from array to serial monitor
Serial.println();
Serial.println("Values from multiplexer:");
Serial.println("========================");
for (int i = 0; i < 16; i++)
Serial.print("input I");
Serial.print(i);
Serial.print(" = ");
Serial.println(muxValues[i]);
void loop()
setPin(i); // choose an input pin on the 74HC4067
muxValues[i]=digitalRead(inPin);
delay(100);
// display captured data
displayData();
delay(2000);
