[SOLVED] 74HC08N doesn't latch ?
Kandy Boy
Newbie
Newbie level 3
Hello , I need some help pls, I am using the SN74HC08N chip. Why doesn't the first AND gate latch itself ?
I have connected the output of the first AND gate to its own input.
After I release the button , the diode should take care by feeding the current from the output back into the input , why this doesn't happen , the LED is not always turned on after I press the button once.
I really need advice on how to latch it
Thanks you all !
Solution
The output of the 74HC08 will be prevented from going to a high enough voltage because the LED will peg it at about 1.6V.
Try adding a 1K resistor in series with the LED.
Brian.
Brian.
    Kandy Boy
Solution
some general rules:
* use a fast ceramics capacitor with very short connection to every VCC and GND of every IC.
* don´t leave any (unused) input floating. It may cause various problems.
Klaus
    Kandy Boy
Brian.
Thank you very much , your solution worked out!
