74922 - keypad driver IC
anasimtiaz
Junior Member level 1
74922
i was studying my microcontroller book in which i found out the keypad interfacing, later i found ther is an IC 74922 which does everything almost with no trouble of programming! im sure its well known here...the question is: are the pull up resistors internally present in the IC, or do we need to add resistors to the keypad...since im making my own keypad, im not sure of the former part.
regards
74922 ic
Yes, 74922 has internal resistor for keypad matrix
ic 74922
Take a look at the attached picture ..
Regards,
IanP
datasheet 74922
ok thanks all! and what value of capacitors to be used for C and 10C??
n1650 keypad ic problem
did you buy already the 74922 chip ??
because you will see that it's quite an expensive chip
and you'd better code it in a small microcontroler ...
keypad driver ic
i got it pretty easily, i can program it in the MC....but the IC is a great invention! so plz let me knw abt the capacitor values
keypad driver chip
As C try 100nF and as 10C try 1µF ..
Regards,
IanP
    anasimtiaz
ic 74922 datasheet
Use this graphic to define C value
Use this graphic to define 10C value
