What is the best book for learning PIC and where to get it?
mohamed saleh
Member level 3
Member level 3
newbie to pic
i am new to pic
i want to know what is the best book for learning pic and where can iget this book from the internet
i want also a pic chip number since there are a lot of pic chips available in the market
Re: newbie to pic
Salam.
Which pogramming language do you intend to use?
Bye.
Re: newbie to pic
The 2 most common PIC used by beginner are the PIC16F877A and PIC16F84A.
Re: newbie to pic
84A is no longer in production. one of the most commenly used nowadays is PIC16F628a to subs 84a. if not mistaken, F88 another version which fancied.
if u wanna use asm, u can start with MPLAB. and if u want to start with C, then u can try MikroC from mikroelektronika. u can even get a html guide for PIC there.
A good place to start. personally, i'm learning PicBasic Pro from microengineering. Good luck there.
If u do some searching here, i guess theres alot of info in eda that u can learn (for beginners) without havin to get a book. although book would help u even more. happy learning n happy searching.
Re: newbie to pic
Hello,
A good book on embedded design in general is "Embedded C" by Michael J pont. Another book is "PIC Microcontroller project book" and "Mike Predko guide to the PIC"
I think you can find all these books in the upload/dowload section on this forum.
For PIC Chip numbers, I started with the 16F84 but it is replaced by the 16F628 which has some nice enhancements.
For C Compilers I suggest High Tech C Compiler integrated with MPLAB, check their website for the demo ( Ithink it compiles for the 16F628 for free). Programming in C saves a lot of time and gets your project running much quicker, of course the compromise is you get a bigger code size and maybe slower than what you can get using assembler.
The important thing to do now is to buy or make yourself a PIC programmer a lot of designs are available on the web (JDM programmer is a simple and easy one). Have the PIC datasheet infront of you, Get some PIC chips and get it starting with some simple routines like flashing a led, then step it up by reading some inputs (switches) and displaying the outputs on LED. The rest you will figure out yourself as you go.
Gam
Re: newbie to pic
hxxp://www.phanderson.com/icd/tutorial.html
PIC16F87X_tutorial_sample of phanderson
using CCS
Re: newbie to pic
I think 16F88 is better choice than 16F628A or you can try 16F877A for more I/O. If you're using C you look at examples from www.microchipc.com
photonix
Re: newbie to pic
Pls try this link :
Very good basic PIC tutorial to get grip on PIC assembly programming.
Re: newbie to pic
Hello,
Where could I find that section with downloads? :) Thanks :)
Read Muhammad Ali Mazidi - PIC microcontrollers; one of best. C and assembly both covered for 16F series.
Thanks
Yes,Mazidi's book is the best one and it covers C and Assembly both for 18F series not 16F series.
Hi
I think this book is useful
  • pic-in-practice-second-edition-a-project-based-approach.9780750668262.27762.pdf
