how to convert binary to BCD or decimal in assembly
mohamed saleh
Member level 3
Member level 3
binary to bcd assembly code
i want to know how to convert binary to BCD or decimal in assembly
i want a code
thanks
convert bcd to decimal
Hello
In assembly you can use an instruction that is DA that means Decimal adjust.
Regards
This is the routine to convert 16bit binary to BCD in assembly
for pic micro.
          CBLOCK 0X20
BCDvalH
BCDvalM
BCDvalL
MCount
NumbHi
NumbLo
           ENDC
; Binary to BCD conversion routine
; 16 bit number to convert is in NumbHi, NumbLo
; result is set in BCDval HML
HexBCD    movlw d'16'
	movwf MCount
	clrf BCDvalH
	clrf BCDvalM
	clrf BCDvalL
	bcf STATUS,C
loop16    rlf NumbLo,F
	rlf NumbHi,F
	rlf BCDvalL,F
	rlf BCDvalM,F
	rlf BCDvalH,F
	decf MCount,F
	btfsc STATUS,Z
	return
adjDEC    movlw BCDvalL
	movwf FSR
	call adjBCD
	movlw BCDvalM
	movwf FSR
	call adjBCD
	movlw BCDvalH
	movwf FSR
	call adjBCD
	goto loop16
adjBCD	movlw d'3'
	addwf INDF,W
	movwf Temp
	btfsc Temp,3
	movwf INDF
	movlw 30h
	addwf INDF,W
	movwf Temp
	btfsc Temp,7
	movwf INDF
	return
	end
hex to bcd assembly
i want a code
thanks
you can use simble method for converting 8 bit binary number into decimal equivelt stored in 3 memory locations
code for 8051 family( let r0 contain the binary number and r1,r2,r3 contain decimal equavelent)
BIN_DEC: MOV A,R0
MOV B,#100
DIV AB
MOV R3,A ; R3 CONTAIN HUNDRED NUMBER
MOV A,B
MOV B,#10
DIV AB
MOV R2,A ; R2 CONTAIN TENTH NUMBER
MOV R1,B ; R1 CONTAIN LEFT DECIMAL NUMBER
RET
how to convert binary to BCD or decimal in C/C++ code
how can i convert hex values that is read from counter 0 of 89S52 to binary or to Decimal values
pls can can i convert hex values retrived fro counters to ascii decimal values which is sent to the serial buffer of 8952 microcontroller
Added after 30 minutes:
How can can i convert hex values e.g (0x40,0x12,0x0A) retrived from 89S52 counters to ascii decimal values e.g (64,18,10) which is sent to the serial buffer (SBUF) of 8952 microcontroller.
can you help me convert 8bit to decimal in assembly language that can be used in pic16f877
Hey, I found this code was exactly what I needed.
Converts 16-Bit (2 Registers) To Unpacked BCD Decimal.
Works on the 18FXXX Series PIC
Integrated this code into my own project as a function call and works like a hot damn. Hope this helps.
Re: convert bcd to decimal
Hello
Regards
hi rapina,
is that possible to convert decimal to binary or binary to decimal conversion in VHDL / Xilinx.
