What is the maximum DC voltage, that is not lethal?
fogl
Junior Member level 1
dangerous dc voltage
More specifically, peak voltage greater than 42.4V is hazardous; voltage less than or equal to 42.4V, or SELV (safety extra-low voltage), is non-hazardous. It is difficult to know when electricity can cause serious injury or be fatal. Contact for only 1 to 3sec with currents of only 6 to 200mA can cause electrocution by disrupting the normal rhythm of heart muscles, resulting in fibrillation and leading to death
Quoted from:
All varies from person to person .. it is very individual ..
Regards,
IanP
dc voltage dangerous
<=60V used for wired phone supply give irritation to most
<=110V US, shock but mostly not lethal
220-240V Europe, on the avarage lethal for about a minute
During the first world war there was a decision to use 220V instead of 110V because then wiring could be a quarter thick. That helps to supply more copper to the battlefield during the first world war.
Ironical because of this 220V decision more people died by violance on the battlefiled than by electric shock!
minimum lethal voltage
There is another lethal side effect. The muscle contraction will sometimes cause the person to move, sometimes moving into mechanically dangerous areas and dying from mechanical damage to their bodies.
what dc voltage is dangerous
Higher DC voltages(over 200V) make blood electrolysys...then very small bubles of gas come into brain...this efect is lethal...human body can be very well and then after 1 or 2 min. :(....otherwords you can smile and think is OK and after
few min...........:cry:
I work with high DC voltages(600-900) 15 years and I think is more,more dangerous than AC.
lethal dc voltage
for 220 AC, there are chances that one can get away from the wire (which he has touched accidently) because AC's alternating nature - the 50 Hz vibration effect is perhaps the main helpful point of rescue.
what about 240 DC ? is will there be any chance to get away ? or sudden death ?
I ask because I am working nowadays with that kind of high DC voltage.
fatal dc voltage
Practically seen, DC is more lethal than AC. It all depends from individual to individual which determines the voltage levels they feel as "lethal". I have one of my close friend Named Rajmohan Nair (Popularely known as "Current Mohan")who is not at all affected by any domestic or industrial electricity. He takes two phases in his two hands and one in the mouth and touches the Neutral with his feet and is still giving shows world wide and is alive.
A part of his performance may be seen on the link given below.
https://www.youtube.com/watch?v=PRf9MqqkMDM
https://my-xperience.blogspot.com/2007/04/current-mohan-electricity-in-human-body.html
lethal dc current
You're asking the wrong question. You should better ask about the required and optional safety means when working with dangerous voltage levels. Any likelihood of getting away in case of accident must not come true in your individual case.
what is the lethal amount of voltage
ok, here is, perhaps, the right question :)
what should the the safety means in case of working with that kind of high voltages ?
I have been in germany so i know that in germany there are strict safety regulations. can you suggest me any safety-how-to ?
For FvM :
Schlecht Deutsch - Verzeihung.
Ich hab' im Dortmund etwa 3 Jahren gelebt und war sehr öfter Buchum meinen Kollegen besuchen kommen. Ich hab's gerade gemerkt, unter Dein ID, dass Du aus Bochum bist :)
Re: lethal dc voltage
Hello, does anybody know how much voltage 'Current Mohan' is able to withstand? And how rare it is for someone to be able to act as a conductor for electricity?
I seen, DC is more lethal than AC. It all depends from individual to individual which determines the voltage levels they feel as "lethal
lethal dc voltage
Hello,
Many standards product standards assume 60Vdc to be safe. For example, look at https://www.ecma-international.org/publications/standards/Ecma-287.htm. This one is free and gives good info on safe construction and safe current, voltage and stored charge.
Also read the assumptions. The safe DC voltage depends, for example, also on the contact surface, moisture and where on your body the contact is (skin resistance varies across your body).
There is also indirect damage. When you are working above ground, 60V may result in falling down.
I wouldn't mind seeing some comment on working safely with 200-400VDC.
I am atm fooling around with PC power supplies, and there's rectified AC to DC 340V there.
I have a isolation transformer, then however earth leakage of that 340V DC I don't believe would trigger the house earth trip switch.
So far I've just been mindful to be very very careful.....
lethal dc voltage
Hello,
An isolation transformer only prevents an electrical circuit (via your body) to ground, but does not protect you from an electrical circuit between two floating wires and your body.
You can see this (don't try it) when you touch both outputs from your isolation transformer, or the terminals of the capacitors following the mains rectifier in power supply.
Note that 50 or 60 Hz AC voltage is more lethal (then DC) as is may result in fibrillation of your heart at relative low current levels through your body. This is the reason that many standards mention 42VAC or 60VDC as a safe voltage.
UL and similar safety standard require a safety interlock for any potential voltage exposures of 42 volts or higher. This comes from the average resistance of a human being with the current levels sufficient to trigger dangerous effects such as fibrillation. When the interlock is enabled (V>=42V), an indicator must light. If enabled and mechanical interlock is broken, the voltage must be shut off regardless of the impact of doing so (destroying devices or equipment).
@jgruszynski
how does such standard help, when your trying to measure and look at circuits with
300VDV + and oscilloscope and/or multimeter.
Finger slip, and ouch high voltage !! i've been careful and no finger slip yet, but what if !!!
What safety precautions do you use ?
Hello,
You are totally wrong. An AC can never be as dangerous as DC. AC alternates and at one time it goes through the zero Crossing and this zero crossing is the point where when u accidentally touch the AC wire, u can release ur self.
Since DC is High all the times, it will never leave u or u cant leave it. that is one of the reason for replacing the main lines from DC to AC.
And if we talk about current, from Myth Busters on Discovery Channel, they said 4 Amps is lethal for a woman and 5 Amps is lethal for man.
The thing is what is the voltage level we can comfortably work with? the 60V in telephone line is not lethal but will keep on irritating u by giving bearable shock so obviously u cant work. So voltage greater than 110V which has no current limitation is Hazardous. A 220V-500W inverter can shock u but cant harm u since its current is limited to 500/220 Amps.
Hello Sajjadkhan:
Finally it is the current and where it goes that determines lethality, even 24Vac can be lethal under special circumstances.
From "Electrical Safety Handbook 3rd ed, J. Cadick, et al"
For 60 Hz AC:
30 mA: Respiratory paralysis, Stoppage of breathing (frequently
fatal).
75 mA: Fibrillation threshold 0.5%, Heart action discoordinated (probably
fatal).
250 mA: Fibrillation threshold 99.5%
(≥5-s exposure)
If fibrillation occurs, even removing the source of current will put you in a very dangerous position without intervention by others.
For currents >4A, your heart stops during the current passage and will function normally after removal of the source. This is the reason why defibrillation units generate so much voltage to get sufficient current through the heart region.
Regarding "let go" current:
1. Victims of DC shock have indicated that they feel greater heating from DC than from
AC. The reason for this phenomenon is not totally understood; however, it has been
reported on many occasions.
2. The DC current “let-go” threshold seems to be higher than the AC “let-go” threshold.
Info directly from "Electrical Safety Handbook 3rd ed, J. Cadick, et al"
The danger of DC (even at low levels) is the electrolysis that damages your cells.
Maybe you should do some investigation yourself also.
On-hook telephone voltage doesn't really give you any shock since no current is being pulled when the phone is in an on-hook condition. Off-hook it's only 30mA-40mA. The real kicker is the 90 to 110VAC from the ring voltage.
