emavil
Member level 2
common cathode 7 segment bc547
I tried driving 1" Common Cathode 7-Segment displays using PIC16F84A. It turned out that the CC 7Seg is dimmer compared to the Common Anode. I'm using BC547 driver transistors with 1K resistor at the base. Why is it after replacing the CC with CA 7Seg using BC557 with 1K resistor at the base, the CA 7Seg is brighter (the same circuit)?
