dineshbabumm
What will be the result if we connect 2 different voltage source(say a 2v and a 1v source in parallel to each other). What will be the net voltage(For both ideal and non ideal cases) if we measure voltage across the parallely connected voltage sources??
My opinion is it will be the least of two(In my example it may be 1 v) in the ideal case as if we connect a 10 v and short it(almost similar to 0v connected in parallel with 10v),the battery gets drained and results in 0v.. But will it be the case really? What will be the result if we connect a 2v and 1v in parallel???
