zhi_yi
Full Member level 4
hi there, please help me.
i tried to build a simple digital clock using 7-segment and controlled by computer parallel port. i use 74LS244 as buffer, and 74LS138 Demultiplexer.
74LS138 outputs is connected to the cathode of the four 7-segments. the 7-segments is common cathode.
i have two problems..
1. from what i see in the 74138's datasheet, the output of the selected pin would only have one pin in low state from 8 pins of outputs, the less would be in high state. but when i tried it, i got two 7-segments light up at once, it would mean that the outputs of the 74138 have two pin in low state at once, please tell me where is my doubt?
2. to change the "numbers" of the 7-segments, i use the data register from parallel port, and connected to buffer 74244, but when i tried it, i didn't connect the port to the input of the buffer, but still the 7-segments could be light up and it show "number 8", why?
i am sorry if there are a lot of grammar error, if it's not clear enough for you guys to help me, i would try to draw a schematic.. thank you..
