AD7730 to interface 10ton load cell with 2mV/V specs
ex4
Full Member level 2
Full Member level 2
Jakarta, Indonesia
Anybody has tries AD7730 to interface 10ton load cell with 2mV/V specs??
Is it can count to 1 kg resolution without any external amplification ??
thanks in advance
ad7730 code
for my load cell 1uV/kg :D
can it be done without any external amplifier???
i calculate from the datasheet, that i can get 4 count for 1uV using only that chip
load cell avr
this is c code for AVR for AD7730 ,can be used for other micros by simple changes.
Re: AD7730 for Load Cell
HELLO!CAN U EXPLAIN CLEARLY IN THIS PROGRAM ? I DONT UNDERSTAND ?EX:
this code ?
void ADC_SPI_Init (void)
//Set SS high --- Set SS, MOSI and SCK as outputs
SPCR = (1<<SPE) | (1<<MSTR) | (1<<CPHA) | (1<<CPOL) | (1<<SPR0); //Enable SPI in Master mode, mode 3
i dont know command code "1<<SPE" ,what is it mean ?
have you seen any examples on C coded for AVR??? check the Datasheet!!!!!
SPE is a bit of the SPCR register... as in avr-gcc you can't access individual bits directly... they use the 'bit value' aproach...
some example:
say SU equals to 3 so we mean to turn on only the bit3
we want this REG = 0000 1000 , right?
00001000 binary equals to 8....
which is the relation between 8 and 3 ???? of course power_of_2 !!!!! 2^3 = 8
in binary, there is a more easy approach of power_of_2 ... it's called shifting...
so we shift one bit theree times...
we have 1 bit only:
0000 0001
... and shift it three times!
0000 0010
0000 0100
0000 1000
now we have the 3th bit activated!!!!
the shift operation in C is ..... << ....
so....
REG = 1<<SU ; from my lil' example...
in your case:
means: on the register SPCR, set the bits SPE, MSTR, CPHA, CPOL and SPR0 and clear the rest...
if you don't know wtf does each bit... you must read the datasheet troughfully....
