Design of sine wave power inverter using PIC16F72
harimelath
Member level 2
Member level 2
Bangalore
application of pic16f72 as a sine wave inverter
Can anybody help me design a sine wave inverter and battery charger using a full bridge mosfet power stage and 50HZ iron core power transformer. I need to use the same transformer for battery charging and inversion.
Basic help for writting program required.
I have made a schematic for the baisc configuration. Will be posted
Hari Melath
pic16f72 bridge sine wave oscillator
LOOK CLOSELY TO THIS THESIS ,
IT IS VERY USEFULL TO YOU,
TRY TO TAKE SOME INFORMATION OF IT,
BUT DO NOT COPY IT AS IT IS.
REGARDS.
ic sine wave inverter
You can also use xc2206 function generator ic for sine wave generation. In this case u need to used digital potentiometers ( try the Xicror NV ram based pots, they are the best)... to control the amplitude and frequency of the sine wave.
