How to reverse the unite command in HFSS
tender_006
Member level 3
Member level 3
ONCE I UNITE THE TWO DIFFERNT BODIES IN HFSS ,, HOW CAN GET THEN INTO ORIGINAL FORM
Re: A SMALL Q? IN HFSS
when you unite two objects, you see one object and there is list of operations under that object. just delete "unite" operation under united object, then you will see original objects just before unite operation.
best regards.
