Simulation of split ring resonator (SRR) with HFSS
rachidrian
Newbie level 3
Newbie level 3
split ring resonator in hfss
I want to redo this article:
Electromagnetic parameter retrieval from inhomogeneous metamaterials
but I have find a big problem in the phase of S11. between 13.2 GHz and 20 GHz
helpe me for to find this probléme?
to see the strusture of SRR +article (fil joinig)
thank's
  • smith_5225.pdf
hfss srr
hfss uses exp(jwt) time dependence whereas the authors use exp(-iwt) time dependence...
srr hfss
have any one trainig works of SRR WITH HFSS simulations ?
Reactions: ansai1
    ansai1
split-ring resonator (srr)
Maybe you will have solved your problem. But for the Post, I have tried several simulations of the provided file. First of all you have to extend the sweep up to 20 GHz. Probably the Solution Frequency is low, but the numerial problem persists. Phases of S11 and S21 seem to be swept. Sometimes, the paper's figures are uncomplete, or the given simualting conditions are not the final ones, not the simulating code.
That's my opinion. Maybe someone else could add more info. Bye,
Pere
split ring resonator srr simulation using hfss
I cannot understand
Why do you use deembed distance 2.5 mm????
srr resonator
can you give the reference of smith.pdf to read because I cannot download?
srr parameter retrieval
hi coungtran;
i downloaded the zip file but only S11 graph can be seen in this file. how can we plot the S21 parameter?
thanks for help
simulation of split ring resonator hfss
hi asonds,
since it has not got the second waveport, you can not plot the S21 i think, you should add the 2nd waveport confronted with 1st one in the same box and resimuler.
srr and hfss simulation
Has anyone been able to reproduce the results of the paper? I simulated the same structure in HFSS (Fig. 2 of the paper) and the results are very different then what they get for S11 and S21.
hi coungtran;
i downloaded the SRR1correct.zip file. I added the the second waveport into the air box. I plugged the equations to obtain the refractive index, permittivity and permeability. But I could not obtain the same result as in the smith paper.
Can you help me to obtain the same results?
Thanks for help
srr split ring
hi
Has anyone been found the same results of the smith paper? If yes, please help me to find the same results. (Especially, the refractive index, permittivity and permeability)
Thanks...
parameter retrieval srr code
I have the same problem , my |S| . Re(Z) and Arg(S) figure are similar to it on paper , but the Re(n). ε and µ are different .
could someone tell me what's my problem ?
ring resonator design using hfss 11
hi everbody,
I have the same problem. I obtained S-parameters but couldn't obtain the correct effective parameter values. If there is anybody that can explain obtaining these parameters?
hfss simulation split ring resonator tutorial
hi all you should write the matlab code of n and z and epsilon and mu that represented by smith in his paper on physical review 2005.
hfss 11 resonator
All,
I don't know if this is still desired or not, but I have been able to simulate the unit cell shown in Figure 2 of the paper, "Electromagnetic parameter retrieval from inhomogeneous metamaterials." The magnitudes of for my S-parameters match what is shown in Figure 3a. The phases of my S-parameters are opposite of what is shown in Figure 3b (i.e. I can plot the correct phase if I plot -Arg(S21)).
Based on these results, I took the S-parameters (I inverted my result for Arg(S21)), imported them into Matlab, and extracted the refractive index, the impedance, the permittivity, and the permeability. My graphs precisely match those shown in Figures 3c, 3d, 3e, and 3f. I will gladly share these codes with anyone that likes them--I didn't post initially because this thread has been inactive for awhile and I didn't want to waste time if it wasn't necessary.
I would like to know why the phases for my S-parameters are opposite to what are shown in the paper. Someone posted this was because the authors use an e^(-iwt) time convention versus the engineering convention of e^(jwt). I know this difference in convention causes issues, but I don't understand it enough to know the exact impacts. Any help would be great.
Pleasant day,
Jeff
floquet deembed
hi jeff
please upload your matlab code.
regards
matlab code split ring resonator
Here is my simulation of SRR, can you upload your Matlab code please
split ring resonator ports hfss
hi jeff
Thank you very much.
