Pcaad5: east antenna design software
antenna software -pcaad5
is this Windows or Dos software?????
It is a useful software for antenna array synthesis
Re: antenna software -pcaad5
why not look at **broken link removed** for linear array synthesis ?
Juppydu,
can you kindly send me a complete version linear array synthesis, in the demo , I can not find the amp/phz, thanks a lot. xcyyx@tom.com
Bets Regards
cheng
hello , whare i can find that software? , i want design a arrar antenna for 12.45 ghz , thanks
Added after 2 minutes:
i try download the software but i ned more points
You have now 0.50 points. You need 5.88 points.
anyone can send me please .. thanks , mike
hello , anyone can send me the PCAAD 5.0 , please , i cant download
satt_tv(at)hotmail.com , thanks
thanks a lot?
can anyone tell the detail bnefits about it?
PCAAD 5.0 is a Windows-compatible antenna analysis, modeling, and design software package. It contains more than 40 separate routines treating wire antennas, aperture antennas, microstrip antennas, arrays, and transmission lines and waveguides. These routines are integrated into a menu-driven, user-friendly system allowing you to quickly evaluate impedance and patterns for a wide variety of antenna types. Some of the new features in Version 5.0 include the following:
• 3-D color pattern plots
• Impedance matching with Smith chart
• Analysis of circular planar arrays
• V-dipole antenna analysis
• Wire loop antenna analysis
• Log periodic dipole array analysis
• More general wire antenna geometries
• Ability to copy graphs to Windows clipboard
• Improved error checking
• Movable labels on pattern and Smith plots
• Improved plot resizing
• Color settings can be saved
• All wire geometries can be viewed in 3-D
• Plotting of E/H or E-theta/E-phi patterns
• Improvements to user interface
• Antenna Short Course included on CD
Apparent problem with PCAAD 5.0, using the linear array pattern synthesis routine: whenever I input anything into the pattern value boxes, the program crashes with a "subscript out of range" error. Is this a bug, or am I doing something wrong?
