Jester
Full Member level 6
I'm looking for stack up recommendations (keeping in mind readily available materials) for a 6 layer board I'm working on.
Design requirements dictate the following:
- maximum 6 layers
- lots of high speed traces DDR3, SERDES, Gbit ETH, USB2.0 etc
- high speed signals due to BGA need to be 4mils wide
So for 50/100Ohm with 4mil traces, the two inner signal layers need to be close to the ground and VCC planes (about 6 mils), this results in a total stack up of only 35mils assuming 4.3mil outer cores and 8 mil center core. So either I have a "thin" PCB at 35 mils or increase the center core to 35 mils or so and that will hurt the inter-plane capacitance.
So is a less than nominal 63 mil board a bad idea (perhaps to much board flex?) or do the advantages of more inter-plane capacitance outweigh a thin board?
Any 50 Ohm, 4 mil trace, 6 layer stack up suggestions are welcome
- maximum 6 layers
