Sunny55
Full Member level 3
I have an idea here to power a PC fan cooling pad that runs on USB(5V).
The power source is from an AC powered smartphone usb charger as shown here.
https://images.mobilefun.co.uk/grap...Micro-USB-fast-2-Amp-Charger-Kit_35895_15.jpg
My thinking is this will WORK if the data cables on the the pc fan cooling pad is not used. ( That's because the cooling pad only need 5VDC & GND pins to work, no data transfer needed).
What do you think? It's going to work?
So to sum up,
USB smartphone charger(5VDC) >>> USB powered pc fan cooling pad.
So to sum up,
