andy40185
Member level 5
Hi all,
I want to design a circuit for supplying 12v to lm741. I have considered to use flyback to fulfil it but I do not sure whether able to
supply the voltage to lm741 simultaneously.(because it relies on the switch on/off to supply the +/- voltage)
Thus, I design the following circuit, it is two boost converter for supplying +/-12v and the duty cycle is controlled by the MCU by
using the timer interrupt. Also, I do not sure to determine the component value, can anyone suggest some acceptable value for the converter?
Is it work??
Regards,
Andy
Is it work??
Regards,
Andy
