HankMcSpank
Newbie level 3
My requirements are for a mono Audio amplifier IC capable of a peak to peak output swing of 4.2V into 8ohms, operating off a single 5V rail (frequency range is about 100Hz- 1kHz) - but an IC that doesn't apply a crazy voltage gain.
Just about all output ICs I've tried apply a voltage gain of 20! this is problematic because I'm restricted to 5V as the supply, so working backover 4.2V peak to peak divided by a gain of 20 means a meagre maximum 20mV input presented into to the amplifier IC!
ok, so I could use a trimpot in the preceding stage to allow maximum dynamic range swing & simply trim off the signal to an appropriate level to present into the amplifier - but I'd still prefer to find an audio IC that's happier with a larger input voltage.
So to my question - are there any suitable IC candidates that folks here have poast exerience with? (only packages in SOIC and larger please)
Any top tips greatfully received!
Also, as a possible route of exploration, is it possible to even implement a classic push pull Class AB amplifier at such a low supply voltage (eg with a preceding opamp to help eliminate crossover distortion) ...if so, which complimentary pair of trannies should I be looking at?
