5V Step-Up Voltage Regulator
I think that Pins #1,3-left unconnected and #2-Positive Terminal of the LiPoly battery and #4-Negative Terminal of the battery.#5-The voltage output that is stepped up.
how do I connect this 5V Step-Up Voltage Regulator with a LiPoly Battery of 3.7V on a breadboard?
That's explained in the link you gave. There's even pictures.
What on earth are you talking about? The module only has 3 pins.
Sorry for the wrong suggestion.My mistake.
thanks for the quick reply, just realized how simple my question was!
The header pins that are recommended look to be too big. They will probably damage the contacts on a breadboard. Use 20 or 22 guage solid tinned copper wire instead.
