dkace
Full Member level 6
![Full Member level 6](/styles/images/ranks/flevel3.gif)
ka 5l0365r
I am trying to repair a dvd player which SMPS is damaged. This IC has the marking 5L0365V252 but the closest I found was : KA5L0365RN from National. It does pretty much the same job, as it is after the transformer the bridge and the 47µF capacitor in the input of the PS, but in order to replace it I have to get the exact IC. I found odd that pins 1,4,5,8 ( it is in an 8-DIP) are not as wide as the 4 inside pins, and there is a damage between Pin1 and Pin2 where Pins are destroyed as if there was an arc developed between them.
Has anyone experience on this kind of chips, or maintance of SMPS? Thanks in advance,
D.
D.
