How to initialize an array structure in verilog?
yuenkit
Full Member level 1
verilog array
for example,
reg [7:0] mem [0:3];
1. I want to initialize the every element in the mem = 0, how to do that?
2. I want to initialize mem such that mem[0] = 2, mem[1] =4 , mem[2] = 1, mem[3] = 5. how to do that?
verilog array initialization
$readmemh or $readmemb is not synthesizable.
u can use it for simulation purpose.
how to u realize in synthesis part?
u must design a simple RAM for synthesis.
Aravind
array verilog
if you use register not memory,please use for loop
to initialization!!
array in verilog
I cant Understand JJWW110.
can u give simple example.
thanks
verilog memory array
i guess what jjww said was
parameter MEM_SIZE = 1024
reg [7:0] mem [0:MEM_SIZE -1]
initial
begin
for (k = 0; k < MEM_SIZE - 1; k = k + 1)
begin
    mem[k] = 0;
end
end
verilog memory initialization
Is this correct? Looks like you actually treat mem as a single bit signal, not a bus signal.
verilog array initialize
of course it is right, I often do as that
How about if I only want to initialize one of the bit of mem? For example, I want to initialize the bit 0 of all mem array to 0?
verilog initialize register
initial
begin
for (k = 0; k < MEM_SIZE ; k = k + 1)
begin
mem[k] = 8'h00;
end
end
verilog parameter array
whether reg [7:0] mem[ 0:MEM_SIZE -1]
the mem should be a ram file in the name of mem or
verilog itself it take as ram memory?
im having ram library of 512 X 8 (file name RAM512X8.v)
how to write or involve it by using array structure like above ( ram [7:0] ---)
Re: verilog parameter array
@weng
You can intialize your bit 0 like this,
initial
begin
begin
mem[k][0] = 0;
end
end
Actually $readmemh and $readmemb are synthesizable. Synthesis tools like Synplify Pro allow initial statements only for those functions. This is an example how I initialize the 2-D array mem with the file contents.txt:
reg [ 31:0] mem [0:4095];
initial $readmemh("contents.txt", mem);
In this case, the TXT file should only have hex characters and does not need to have the contents for all locations. For instance, something like this will initialize only the first location:
F3FA0B59
i want to iniatialize array of reg [7:0]arr[15:0] using for loop ? anybody help me please..................
Hi jhunjhun, if you want to initialize the whole array with zeroes or ones, then you can use the approach presented by jjww110 (see above). If you have the initializing data in a file, then you use the tasks readmemh or readmemb (see above too). Could you share an example of the initial contents for a better picture of your problem?
my problem is:
reg [7:0]arr[15:0];
reg [7:0]i;
reg [1:0]state;
always@(clk)
begin
case(state)
2'b00: begin //arrary arr initialization//
arr <= i;
if(i ==8'hFF)
state = 2'b01;
else
begin
i = i+1;
state = 2'b00;
end
end
2'b01: begin
end
endcase
end
jhunjhun, for a synthesizable memory initializer based on a state machine, I would only recommend you to initialize the addressing variable i.
input	clk, reset;
// Declare states
parameter S0 = 0, S1 = 1, S2 = 2, S3 = 3;
// Declare max address (it could be less words)
parameter MAXADDRESS = 8'bFF;
parameter FILLINGVALUE = 16'b0000;
reg [7:0] arr [15:0];
reg [7:0] i;
reg [1:0] state;
always @ (posedge clk or posedge reset) begin
	if (reset)
		state <= S0;
	else
		case (state)
		S0: begin
			i <= 0;
			state <= S1;
		end
		S1: begin
			arr[i] <= FILLINGVALUE;
			if (i == MAXADDRESS) begin
				state <= S2;
			end
			else begin
				i <= i + 1;
				state <= S1;
			end
		end
		S2: begin
		end
		endcase
	end
end
If you want to fill it with the address, you will have to pay attention to the word length.
thanks..........
But if i want to fill data in array like as i incrementeted arr <= i .
thanks..........
F3FA0B59
k, for 1st locatioin, how to initialize all the memory locations.....
Alvaro, I know it is more than one year later, and I'm posting only for the "future" generations :)
I found this post when looking for a code for this same initialization, and maybe could be useful to let a very small contribution also:
On the S1 state, I think it would be better to test if i is equal or greater than MAXADDRESS instead of equal to, in order to increase the tolerance to faults (if MAXADDRESS is not a power of two).
Maybe something as:
		S1: begin
			if (i >= MAXADDRESS) begin
				state <= S2;
			end
			else begin
				i <= i + 1;
				state <= S1;
			end
		end
input	clk, reset;
// Declare states
reg [7:0] i;
reg [1:0] state;
	if (reset)
		state <= S0;
	else
		case (state)
		S0: begin
			i <= 0;
			state <= S1;
		end
		S1: begin
				state <= S2;
			end
			else begin
				i <= i + 1;
				state <= S1;
			end
		end
		S2: begin
		end
		endcase
	end
end
Thanks,
Josias
