555 timer & parallel LEDs
des.xav
Newbie level 2
st-hubert, quebec
Hello to everyone,
I use a 555 to flash around 50 leds in parallel. The leds are made in a plastic strap, like a belt, and I want to flash 50% on/off.
The 555 is limited at 200mA and every leds use near 20mA....so I need around 1A (minimum!).
I was looking to use a TIP31 at the output (pin3) of the 555 to drive that high current.
Is it possible, or leds in parallele cannot flash?
Thank you,
Xavier
Hi, you can use TIP31 but look into the datasheet of the transistor and calculate the Rb to protect your ic from getting damage.
Connecting several LEDs in parallel is not a good idea ..
Instead consider combination of series/parallel connections (+resistors) .. see attached example ..
Rgds,
IanP
ok I think a resistance of 220 or 330 ohms will be ok (Rb) to protect the transistor.
The strip of leds I have is in parallel so I dont have the choice to keep it like that.
So the thing is, at the end, I need to drive around 1 Amp to light those leds.
Each led already have a resistor of 330 ohms integrated in the strip.
I build my circuit and see what happened. Thank you!
X
It is much better that you have a resistor in series with each led, this will prevent current hogging. You just need a transistor or mosfet with sufficient current carrying capability. If you dont mind it clicking, you could use a small relay, 555 will drive or sink 200ma, plenty enough. Dont forget to use a diode or vdr across the coil though, cathode to plus.
