Generating sine wave using PWM method
Maverickmax
Advanced Member level 1
generate sin wave with pwm
Hi
So far I understand to generate sine wave look-up table. Now I need to know how to create algorithm to use the table with PWM in order to produce sine wave.
Any good tutorial or link for me to develop my understanding on this area?
Maverick Max
generating sine wave
Maverick Max
The PWM period must be much shorter than the sine wave period. Let's say for example, the PWM period is 256 counts and there are 36 PWM periods over a sine wave period (each PWM period is 2*pi/36 radians or 10 degrees).
Let's say that at a value of zero, we are using a PWM period of 50%. Negative one is 0% and positive one is 100%.
For each PWM period, you use the sine table to determine what your duty cycle should be. For sin(0), PWM = 50%, count=128. For sin(2*pi/36), PWM = 59%, count=151, for sin(2*pi*2/36), PWM = 67%, count=171, etc.
So your output is high for 128, low for 128, high for 151, low for 256-151=105, high for 171, low for 85, etc. throughout the period of the sinewave.
Basically, all you do is compare a counter to the appropriate value in your table. The result of the comparison yields the state of your output.
Reactions: sebinphilip
    V
    V
    sebinphilip
generate sine wave using look up table software
hi,
pfa an apllication note for avr mcu to generate DTMF using PWM. this should tell you how to generate sine wave usin PWM.
lm555 sinewave
jonw0224 said:
Maverick Max
Cheer for giving me some idea...
what about using of PWM frequency such as 5kHz and generate 500Hz while fclk is 40MHz?
Do I need a forumla to detemine this out?
Maverick Max
pwm rc sin
for 256 count for each PWM pulse as jonw0224 said, you need ;
F(clk) = F(PWM) * 256
in your example:
F(clk)= 5000 * 256
you can use frequency divider to yeild this F(clk).
pwm sine table
Hi
Since I have managed to understand how to generate sine wave. Now I need to know how to vary frequency (speed).
Does anyone know how to do it?
Maverick max
generate sinus wave pwm
You can change your PWM period or (more preferred) you can change the number of PWM periods per sinewave period.
metho of generating sine wave
Do you have any example for me to implement variable frequency?
Maverick Max
avr pwm generate sin wave negative
you can use RC clock source such as LM555
generating sine wave table
Actually Im more interested in software...
Maverickmax
