About VCO Design Examples in ADS
Apollo_gu
Newbie level 6
Newbie level 6
vco ads
Hi
Anyone can offer some reference design about VCO in ADS, i am a new designer.
Thks and Best Regards!
Apollo
ads vco
I have written a tutorial. I hope it is useful. I got most materials from the oduseus's web but I have modified it for my application.
vco design project
Dear boy,
An excellent tutoirial!!
Do u have any other tutorial or weblink or an example for VCO implementation at the frequency of around 7GHz, which includes distributed model for passive components........and also layout design for the complete structure?
--X--
ads vco design
Here attached one project of VCO with ADS
ads vco example
At 7 GHz, you might use a transmission line as a resonator. I have done an osc at 5 GHz using a transmission line on Roger substate. It works fine. I have nerver tried at 7 GHz. You might also tried to use dielectric resonator. ADS has a model for it
ads tutorial vco edaboard
Hi boy,
Do u have any tutorial file for that 5GHz VCO. I mean ur project report or some sort of details that could beneficial for me in order to understand the VCO designing steps at 5GHz?
I hope u would not mind to share it.
--X--
vco design
I have a tutorial written in chinese ,can you understand it !IF you do, i mail it to you!
Added after 1 minutes:
and meanwhile I want data above me.hehe
Reactions: rf_hak
    rf_hak
voltage controlled oscillator design with ads
I'm sorry I saw your email just now due to the unconvenient net ,and I'll sent it to you later,and i meet a problem:that is how can i choose the mosFET when i want to design a VCO operated at 5 GHz ?i try to do it,but i can't find the mos i want....help me!kindhearted gentlemen or ladys or girls! i want a detail example about vco or oscillator by ADS or Hspice! notice:5Ghz cmos integrated design! Thank you very much!:cry:
login design examples
any ADS example for LC VCOs?
ads tutorial vco
You can use MOS technology files and convert them in ADS for your simulation. For example 0.18um or 0.13um
ads vco tutorial
how to convert?for examples, if I had the parameter of a kind of mos,how can i transfer the system mos in ADS?or how can i buide a new mos by myself?if i want the mos operated in 2.4GHz or others,how can i choose it?thanks!
vco design using ansoft designer
thanks!Can anybody upload more?
I need chinese tutorial
please email me :sw_seu@seu.edu.cn
Thank you!
Added after 26 minutes:
I need some VCO design example in ADS
please email me sw_seu@seu.edu.cn
thank you!
vco design cadence tutorial
is it possibal to design it by using cadence tool?
But what i heard from my prof said that cadence assume the circuits to be linear
Added after 7 minutes:
for phase shifting, does that count for linear circuits?
vco ads zap
no it is not
coz it has frequency shift
vco simulation in ads
the attached file is a example from rfic,written by john
design vco by ads
good, would you give me a copy to icdetf@ust.hk. Chinese is also ok.
I need a example in cadence.
who have a example of vco in cadence. Please share me a copy to icdetf@ust.hk. Thank you!
vco with ads
Here's another example..
  • a_2.45_ghz_low_cose_vco_7626.pdf
