free PCB Footprints library
ulaska
Member level 3
Member level 3
pcb footprint library
is there any free PCB footprint libraries for PADs PCB on the net?
thanx.
PCBLibraries.com also generates high quality 3D models alongside footprints, just enter component dimension data from spec sheet. There are 3D STEP output files from the Library Expert software on this page:
https://www.pcblibraries.com/Products/FPX/3D-STEP.asp
If you're only looking for footprints, you can get the free footprint generator "PCB Footprint Expert Lite" based on the IPC-7351C from here: https://www.pcblibraries.com - this program will create unlimited footprints to any major CAD format at no cost. It actually outputs footprints to your native CAD format. Only catch is you cannot save the CAD neutral data (for later retrieval or cross CAD use), nor change the default preferences.
