50Hz UPS- built-in body diode of FET for charging battery?
xyz9915
Member level 4
Member level 4
Pakistan
50Hz UPS
Please view the attached schematic (for example only), which is a simple inverter circuit. I want to modify the circuit to make it Uninterruptible by adding relay for switching over from mains to battery & battery charging cut off function. My question is that can I use built-in body diode of FET for charging the battery?
Re: 50Hz UPS
xyz9915 ! I post this cicuit for masterleous
Yes you can use the internal diodes but you have to add a current limiting resistor
to limit inrush current becauce it will destroy MOSFETs when battery draw huge
current at start.
50Hz UPS
normal inverters use a taping at 140v or 180v and supply will give to the transformer by a choke or capactor to limit current and to boost voltage (charging volt)
