Simply you use 7805 regulator simple to design because it has only 3 terminal.google it to find datasheet.
Hey Mcplay,
Heres something else you can do after rectifying the mains and it works with a wide range of input voltages! I tested this and it works rather well with accuracy of upto 10-25mV. Although the driving stage is not very stable, still pretty good. Just another idea/
Hope it helps
K
I asked my supervisor to use IC component he said I can use it , please anyone who have an idea of how can I build a power supply with an output of 230v AC and produce the output of 5V dc using IC.
You give us small informations.
1. Do you mean transformerless or with transformer design ?
2. To clear situation, on end you can use IC ?
For design including transformer you can use standard circuit for 7805 :
For transformeless design you can use :
