5-band low noise graphic equalizer
transfomer
Newbie level 1
low noise equalizer
This circuit uses an **broken link removed** op amp to form a 5-band low noise graphic equalizer. It provides 15dB of boost or cut over the 5-band range. Signal-to-noise ratio over a 20kHz bandwidth is better than 100dB refered to 3v rms input. Larger inductors can be replaced by active inductors but this reduces the signal-to-noise ratio.
As shown, the circuit can't achieve +/- 15 dB control.
Reactions: nickoe
    nickoe
