4x4 matrix keypad ,LCD & Atmega128 interfacing problem?
nihal_2000
Member level 1
India
Hi friends,
I am trying to interface a keyboard and LCD with ATmega128. I have manage to get lcd going but keyboard seems to be creating some problem…..it is not printing 1,5,9,13 which are on first row and first column.
Please try to find this strange behavior code and ckt is attached with.
Please help me!
I have tried every possible thing with hardware ....i think there is some bug in my code it self please .....if you find guide me.
#include <avr/io.h>             // Include file for AVR
#include <util/delay.h>
#include "lcd.h"
#define keyport PORTA           //Keypad Port
#define keyportddr DDRA         //Data Direction Register
#define keyportpin PINA         //Keypad Port Pins
#define col1 PA0                //Column1 PortA.0
#define col2 PA1                //Column2 PortA.1
#define col3 PA2                //Column3 PortA.2
#define col4 PA3                //Column4 PortA.3
#define TRUE 1
#define FALSE 0
unsigned char keyval;   //A variable
void key_init(){
        keyportddr = 0xF0;
        keyport = 0x0F;
unsigned char get_key(){
        unsigned char i,key=1;
        for(i=0;i<4;i++){               //Loop for 4 rows
                keyport &=~(0x80>>i);   //Make rows low one by one
                        if(!(keyportpin & (1<<col1))){
                         //check COL1
                                while(!(keyportpin & (1<<col1)));
                                //wait for release
                                return key;
                                //return pressed key value
                        if(!(keyportpin & (1<<col2))){
                         //Check COL2
                                key += 1;
                                //Second key pressed
                                while(!(keyportpin & (1<<col2)));
                                //wait for release
                                return key;
                                //return key value
                        if(!(keyportpin & (1<<col3))){
                         //Check COL3
                                key += 2;
                                //Third key pressed
                                while(!(keyportpin & (1<<col3)));
                                //Wait for release
                                return key;
                                //Return value
                        if(!(keyportpin & (1<<col4))){
                         //check COL4
                                key += 3;
                                //Fourth key pressed
                                while(!(keyportpin & (1<<col4)));
                                //Wait for release
                                return key;
                                //Return key value
                key +=4;        //Next row
                keyport |= 0x80>>i;
                //make read row high again
        return FALSE;   //return false if no key pressed
int main(void){
   MCUCSR=0x80;
      MCUCSR=0x80;
   //Initialize LCD module
   InitLCD(LS_BLINK|LS_ULINE);
   //Clear the screen
   LCDClear();
   //Simple string printing
   LCDWriteString("Type the Number ");
   key_init();
   while(1){
      keyval = get_key();
      if(keyval != 0){
               LCDClear();
               LCDWriteString("You have entered");
               LCDWriteIntXY(1,1,keyval,3);
Re: 4x4 matrix keypad ,LCD & Atmega128 interfacing probl
Hi friends, thanks for your cop ration, I manage to get rid of this problem...Just making keyport high before making rows low.
                keyport |= 0xf0;           //Make rows high
                         //check COL1
                                //wait for release
                                return key;
Reactions: king15
    king15
