masifshahzad
Newbie level 6
I have designed 5KVA inverter which is using 4 batteries in series giving 48V. I am using IRF640N mosfet which is 18A mosfet. My transformer is 48-0-48 so i have used 12 mosfets in parallel at one side so i am using 24 mosfets in total. But when i check my inverter on small transformer its working fine but i connect it with my 5KVA transformer it burn all the mosfets of one side (11 mosfets).i use 35A diodes at the input of 5KVA transformer. Could you please tell me why mosfets rae buring but only of oneside?
Added after 14 minutes:
i am generating 50Hz squarewave from CD4047 IC and after it i am using ICL7667 which is MOSFET driver.Could you please tell me whether the problem is with transformer or selection of MOSFETs. around more than 100amp or current will flow from one side of mosfets (12 mosfets) so each share less than 10amp.
Added after 6 minutes:
The circuit is working fine with small size transformer which is 12-0-12 to 220V of around 2 amp.
One important thing is that mosfets burn when i switched on the circuit and no load is connected at the output of 5KVA transformer.
