mcmsat13
Member level 5
Please I need your help here. I apologise that this thread might be seen as question that one or more members have already asked but bear with me because this one is unique with many reasons.
I'm working on a 48v Inverter system, using MOSFETs as the switch. The switching topology is push-pull, 12 pcs of IRFP260N on each side. Each MOSFET has 12k on gate to source. As they are in parallel, I think this means 1k gate to source resistance?
Gate series resistor is 47R.
The problem is that I use a separate pair of MOSFET for testing this Inverter, one on each side, with 1k gate to source and 47R series R, still if I switch the power...boom!!! The two MOSFET blow like Christmas banger! My driver is the popular SG3524N and IR4427 MOS driver. I removed the driver and use Totem-Pole, all the same! The Oscillator/driving stage is supplied with 12v and removing the leads that go to gate, I measured;
frequency = 51Hz
duty cycle = 49.99%
voltage = 5.86V.
Remember, rail voltage is 48v which is at 54v at the moment. The trafo is a working one. It is from another working system of the same config.
I have looked at the drivers, nothing is wired wrongly! The MOS BLOW INSTANTLY AT POWER UP!
Please what else can I do?
frequency = 51Hz
duty cycle = 49.99%
voltage = 5.86V.
