Why does CMOS technology dominate in VLSI manufacturing?
davyzhu
Advanced Member level 1
oriental
Hi all,
I answer: Save power for its pull-up and pull-down archetecture.
Any other reason?
Any suggestions will be appreciated!
Best regards,
Davy
The following are some of the reasons that I can think of:
1) It is cheaper then Bipolar process
2) Better integration
3) The world top foundry are in CMOS process. Huge capacity to drive cost down.
4) Smaller in size.
    davyzhu
one thing might be low power consumption compared to bi-polar technology.. and ability to maintain accuracy when it comes to microvolts of operational potential ..
bipolar tech. was much popular when it comes to large voltage applications..robertness towards varying parameters.
with regards,
arun
    davyzhu
The most important reason: It's cheap.
Area is another important reason.
absolutly yes.. cmos tech occupies less area and easier when it comes to implement universal gates..nand gates.. somethin which is much better than biploar technology.. that cud be all the more reason why..
with regards,
arun
Hi
1. Rail-To-Rail swing (GND-VCC)
2. High Noise Immunity
3. Low dynamic power (only in transitions)
4. Low static power (low leakage)
5. High Density due to low power (heat dissipation rate)
6. Well-documented and characterized technology
7. Good EDA Tools for design and validation of design in pre-layout and post layout
tnx
    davyzhu
I agreee with most points of upstairs. But for point 2, I'd say CMOS is notorious in generating noise. Actually, leaving out of cost consideration, GaAs, BJT etc. perform far better than CMOS. In military application, you'll find much less CMOS products than in market.
    davyzhu
Hi
What I have pointed is not 'noise generation' but noise immunity'. I mean what range of input deviations due to noise may not affect the output and logic states.
tnx
less area
less cost
less power
CMOS has a full swing in voltage at the output.
It is a voltage controlled device that makes it operate with less leakage current.
The processing of cmos easier than bipolar devices.
even though speed of operation is less compared to the BJT's it is used more because of it occupying less are,consuming less power, many fab's use the cmos technology for fabrication.
PERFORMANCE OF CMOS will detoriate once the operating frequency increases(power consumption proportional to square of Frequency) that's we are using TTL for high freq.and CMOS for low freq.
But CMOS is having high noise margin than TTL
PACKAGE DENSITY is also touchstone for its performance
